2stroken
Seems like my reverse is getting worse on my 07 phazer. Before usually could just rock it and get it to engage, lately been worse and worse. I have done a few things.
1. Idle is around 1800
2. I have put a little more slack in the chaincase
3. I have updated the grommet for the reverse
Is there an updated belt? What are the shimming instructions for the secondary?
Take the secondary apart and add one washer in between the sheaves.
2stroken
part number for the shim? Video of the change?Take the secondary apart and add one washer in between the sheaves.
2007 Yamaha PHAZER FX (PZ50FXW) Secondary Sheave
Shop online for OEM Secondary Sheave parts that fit your 2007 Yamaha PHAZER FX (PZ50FXW), search all our OEM Parts or call at 269-385-1540
#6
2stroken
Is number 8 the circlip to be replaced? Thought I had read somewhere that it needs to be replaced.![]()
Shop online for OEM Secondary Sheave parts that fit your 2007 Yamaha PHAZER FX (PZ50FXW), search all our OEM Parts or call at 269-385-1540www.cyclepartsnation.com
#6
I rarely do unless it appears damaged or worn.Is number 8 the circlip to be replaced? Thought I had read somewhere that it needs to be replaced.
Just remember with circlips only to open them up enough to remove. Not any extra.
