phazer trouble need help
jeep_in_deep
i just finished yearly services(longest oil change ever). then i took it out for a ride and it ran fine. the next night i go to start it up and the green drive light it blinking, and it wont go into reverse, it gets up to 4000rpms and bogs out we checked the tors and bypassed it, it still dosnt work. the sled has only 450miles on it. what should i do?
What all did you disconect durring the oil change. Did you recheck the oil level after you started it. Also it must be warmed up and within a minute of shutting it down when you check the level. It sounds like it's not happy with the level of oil. And is basically in a limp mode. Don't know if it does the same thing if overfilled but I would start at the oil level and go back through everything you've touched. Also any codes coming up?
Just a thought. If your drive light is blinking,try to turn the gear box or the secondary clutch until the light is on. Motor off.You could be stuck between gears.
i forgot to mention that it moves in drive but only to 4000rpm i took it all apart again and checked every connector and cant find it out whats wrong.
are u letting it warm up? mine wont let it rev over 4 grand if its not warmed up. is the red temp light on? cause if it is wont rev up.
yes its warmed up.. this machine was running perfect and it was parked overnight in the shop and when i went to take it out, drive lite flashes and will not rev but it moves...
I Don`t think you drive light should be blinking,With the key on engine
not running.Shift from drive to rev to see if you get a solid yellow light?
If you do get a solid yellow start it up and see if your rpm go past 4000rpm.
Go back in forth from rev to drive it should give you a solid light.
You need to bring it to the dealer, You have an issue with your reverse box. There is an update on the reverse switch.
