PICKING UP CODE 85
F7
On my 06 apex it has a mcx turbo.Just bought the sled used.It picking up the 85 code when you start it sometimes then you shut it off start it again and its gone.The code says open circuit to oil sender or ecu sled seems to work fine any ideas.
code 85
Just had the same problem with my apex. During my turbo install I forgot to hook up the oil pressure sensor wich is directly behind the battery on engine. I think a yellow green wire. Once I plugged it in the warning went away. Also check for a worn or freyed wire.
