- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The CR9EK does not have a solid terminal on the end, you would need to add the screw on terminal caps. The CR9EKB has the solid terminals originally.
seanmurphy26
Elevator Ryder said:what is the difference between cr9ek and cr9ekb i was told they will both work. I hate to put in the wrong plug. Thanks
ekb is dual electrode, e is single. im running single and they feel better then the daul electrodes.
plus what he said^^^^^^^
ya need to screw on a terminal
Elevator Ryder
I know this probably sounds stupid but what are terminal caps? Can I use the terminal caps off the old plugs? Sorry if this sounds stupid but i believe I fouled my plugs and I cant get the proper plugs for at least a week. I just want to ride my sled tonight!
There is always the YFZ plug you could use and much more common.It only has one electrode though.CR9ES.Do a search for YFZ 450 plug though to be sure of that number.Other option is to spray them clean as possible with carb cleaner and then use a blow torch to burn more off.Before trying to start it I would put fresh gas in.Lot of fouled plugs due to stale,old gas.
