Pod-300 coolant temp?
radianguy
Corner Brook Newfoundland, Canada
Canada
2009 Yamaha FX NYTRO XTX 1.75
I just installed a pod-300 so I could keep an eye on my afr readings.
I put the auto tune back on the sled, and hooked the pod-300 up, it worked fine. Afr readings work, engine rpm works, throttle position... Coolant temp has no reading, what would I need to do to get a reading. Was hoping I could remove my koso temp gauge and just use the pod300.
Splice in to the coolant temp sensor. Hook that wire to the pcv. Figure out what voltage corresponds to what coolant temp. Fill in the table in the pcv software.
