radianguy
- Jan 1, 2007
I just installed a pod-300 so I could keep an eye on my afr readings.
I put the auto tune back on the sled, and hooked the pod-300 up, it worked fine. Afr readings work, engine rpm works, throttle position... Coolant temp has no reading, what would I need to do to get a reading. Was hoping I could remove my koso temp gauge and just use the pod300.
kennyspec
- Sep 30, 2009
- stonewall, manitoba
- nytro
You can use the 0-5v input on the pcv and monitor coolant temp that way using the sensor.
radianguy
- Jan 1, 2007
Yeah I emailed the guys at power commander, they told me the same but how do you actually do that?You can use the 0-5v input on the pcv and monitor coolant temp that way using the sensor.
kennyspec
- Sep 30, 2009
- nytro
Splice in to the coolant temp sensor. Hook that wire to the pcv. Figure out what voltage corresponds to what coolant temp. Fill in the table in the pcv software.
radianguy
- Jan 1, 2007
Ok thanks, but that's over my head lol
