MOTOWN SPEEDFREEK
SPEEDFREEK said:cindy called me today, havent heard back sence i called her back!! 8)
My 2 are on the way per cindy at CCS.Will have them for first ride.!!
Impact1
- Nov 12, 2005
safety first
Nos-pro, I did receive your info. Its been crazy at the office. A rep will call Saturday or worse case Monday. Sorry,I did not get a chance take and post some pictures of the CSS on that 05 warrior. I will try to get them up on our site tomorrow. Thanks Guys!
DaveyBoy
I would like to see close ups of front and back of these lights please i didnt see any on ur site either Thanks Davey
- Apr 14, 2003
- Hessel, Michigan
Thanks Chris, I will be expecting the call.
Impact1
- Nov 12, 2005
warrior pics
I got a couple pictures of the CSS on a Warrior up on the Impact site. Go into the photo section and click on the ones you want to enlarge. These should give you an idea on the mounting location.
Impact1
- Nov 12, 2005
On an Apex with a factory low profile windshield I recomend the optional handle bar mount kit. I will get some updated apex pictures this coming week.
DaveyBoy
Great idea but i dont care for the design at all by looking at it in pics seems to big for my likeing,Couldnt it be made smaller,or incorparated in a hand guard would be cool How much does it weigh where are these being hooked too?Where is the closets place to see any in massachusetts are u going to anymore showings?
Impact1
- Nov 12, 2005
Safety
Thanks Dave for your interest in the CSS. The CSS is only 2"x 3" in size and weighs 5oz. with the mounting system. They are powered by any fused 12 volt wire such as accessory plug,ignition or headlight. The average install is only about 10-15 minutes. We are not doing any shows till mid winter. Thanks.
- Apr 14, 2003
- Hessel, Michigan
Moved to Safety section, but still left a shadow
Impact1
- Nov 12, 2005
Thank you guys that already purchased the CSS.Your orders were shipped out today. Please let us know if we can further assist you.
Sled Dog
Mine are on the way was told today. Is the wiring instructions included?
- Apr 14, 2003
- Hessel, Michigan
Mine is on the way!
Will mount as soon as I get it.
Boston RX1
Chris, I just ordered mine as well. Thank you. Now us Yamaha guys need to convince you to ride a better sled. I will not tell the guys what you ride, but it is not blue. At least you wife got it right. Hopefully some day you will see the light. No pun intended.
Impact1
- Nov 12, 2005
Sled dog,The instructions are very clear/easy as to the install.They even have color component pictures. As far as the power hook up, use a test light or a volt meter to find a hot wire.(sled running) If you cowl/hood mount it, run your power wires to a head light or dashlight power. Its just two wires.The black with a white stripe is positive and the all black wire is neg. The CSS is protected if you get the wires reversed in power. If you handle mount it (only w/bar mount kit) run your power wire to the ignition power. If you have a New Apex you can tap into accessory plug power. You can buy a plug adapter to plug directly into the acc.port from any electronics store. I suggest leave the port open for other accessories like a G.P.S. The CSS has a quick disconnect so you can remove it if needed.(theft,covering)
Impact1
- Nov 12, 2005
Boston,You caught me.Just for the record I believe in all of yamaha's products especially there sled line. I bought a new yamaha every year till 04. My last yamaha was an 03 Rx1. Even when I left yamaha I new I would return after they worked out a couple issues.(susp/handling,weight,) In my opinion the New Apex line is Top shelf. Its the high performance mercedes on snow. I find yamaha to be amazing in industry foresight and technology and QUALITY.
