rayone02
- Dec 3, 2010
- adrian, mi
- 2012 Apex 2012 nytro xtx 2006 attak
Anyone using the pod-300? Looking for opinions on use and any issues.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Works great. Love the recording feature for testing and racing.
stone88
Been using it since last February on my low boost MCX and it works great no need for any other gauges as it does it all and records all my runs. I would recommend it.
I have 2 of them.. awesome product!!
rayone02
- Dec 3, 2010
- adrian, mi
Does it have a boost gauge?
stone88
As long as you have the pti it does
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
Given that you already have a PTI PC, how does the POD 300 express the boost pressure. PSIA, PSIG, BAR ?
shagman
Vendor
- Feb 18, 2014
Mine shows psi.Given that you already have a PTI PC, how does the POD 300 express the boost pressure. PSIA, PSIG, BAR ?
titanrcr
- Jan 3, 2011
2015 Viper LTX SE
2011 Apex
Mine shows psi.
Thanks, looks like that will be my gauge solution. Can you also show both the boost and A/F on the screen at the same time?
shagman
Vendor
- Feb 18, 2014
There are multiple screens you can setup. I have one with boost and afr. Another with rpm, boost, afr, and throttle position. You need autotune to display afr. I don't run autotune as its just used to connect wideband O2 sensor.
rayone02
- Dec 3, 2010
- adrian, mi
Just answered a big question for me but would individual gauges be better? I have lcd 200 have had screen freezing and other issues is there issues like this happening? I have purchased gauges just hesitate to sell I like the idea of one gauge and be able to record runs.
shagman
Vendor
- Feb 18, 2014
Ran all last winter. No problems, worked great. No freezing. It's easy to read when testing. Also the record feature is awesome. I record throttle %, rpm, injector % for all injectors, afr, boost when testing clutching and other setups.
stone88
Here's an idea what you can expect to have plus you can adjust to your liking and change it at any time View attachment 110748iView attachment 110748
rayone02
- Dec 3, 2010
- adrian, mi
Like the look and function of that just have to sell my gauges.
- Apr 14, 2003
- Hessel, Michigan
X2!!!
