Powercommander pod 300 display
So if I want to have AFR numbers displayed on a POD 300, I need to get an autotune or another 02 sensor on the pipe before the can?
Need help...
I just installed the pod-300 and it wont display anything. Gauge comes on but not reading PCV. Do i need a can termination plug on the PCV ???
I ad the LCD200 for two years of freeze& recalabrate about every frickin day and I dont run it in winter temps . Got the POD from Allen last Jan and man what a diff !!! Easy to read & program or add & subtract fuel ya dont have to be a dam geek squad to use it. I would sell mt LCD 200 CHEAP LOL
Love my POD300. Sold all my individual gauges. I run the PCV PTI w. autotune. Best part of the POD is the data logging feature. What a great way to be able to dial in your sled!
Need help...
I just installed my pod-300 today, hooked my auto tune back up for the afr readings, installed the pod-300 and everything worked perfect, no programming involved.
Only issue I have is I'm not getting a coolant temp reading, what would I need to do to get a coolant reading?
Yes there is only 1 cable the plugs into the pcv from the pod and everything should appear as long as you have a wideband or autotune for AFR readings.
It should read your temp off the stock thermostat.
Were you able to read temp. I didn't think that was possible. I would like to make mine work also
