PowerMadd Riser on a 2005 RX1....anyone done it?
SIMMER
Niagara Falls, NY
Hey guys,
I don't want to fiddle with my cables but I would like to get some extra height. What's the maximum height I can go without having to extend my cables?
Should I go with the Pivot Riser Block or the Straight Riser Block?
Thanks in advance. :Rockon:
I put a 2" PowerMadd on my '03 (non pivot). I'd say 2" is the max as my cables have very little slack remaining. I also had to remove a few cables from their normal routing under the handle bar (where they ride inside the cable bracket attached to the handlebar mounting bolts). I didn't feel I needed the pivot as the pivot allotted by the stock bars was sufficient for me.
Jon
I put the non pivot on mine, no problems except when turing very hard right. The throttle cable pulls the throttle and the TORS kicks in. I will be extending the cable.
All of the wiring is fine with a little re routing.
I have the Rox 2" Pivot with no issues. I like it much better than the non pivot riser I had on first.
I was looking at that also.
My thought was the riser with the left hand throttle. The splitter would give the cable extentions. ??
I have a stock '03 mtn cable if anybody is interested. It won't do me much good with these.
Jim
