Snoxracer242
Ok I have installed my team clutch kit, it comes with a spring and weight for the primary clutch. I installed the weights per teams directions (1 gram in the tip) and the new spring. Now my belt clearance is way too wide and engages hard off of idle. How do you adjust or change the belt width, from what I am gathering its not quite as simple as a good ol' P-85 Polaris clutch.
What are your thoughts on running a wider belt, 1 7/16" verses a 1 3/8"
Any help would be great!
