@123
stock weight or dalton?I've been running the blu/brn/blu all winter with good luck and much better than stock. Engages 2650, great fuel mileage and holds rpm on top. Excellent trail spring, but jury is still decoding if it' a drag race winner???
Brian Friebel
what spring are you running in the secondary with it ?I've been running the blu/brn/blu all winter with good luck and much better than stock. Engages 2650, great fuel mileage and holds rpm on top. Excellent trail spring, but jury is still decoding if it' a drag race winner???
iceback
Stock primary spring with glide washers, super tuners. Stock secondary spring at 3/3 , TPI 33/35 helix , 270 hurricane High elevation 16.5 psi, no blown belts so far with deep snow , steep pulls. 60mm offset
Fleecer
- Jun 13, 2014
- 2019 SRX
Dalton weights and stock rear spring.
Brian Friebel
I wouldnt of thought the engagement would of been that much lower. My stocker engages right at 2950 to 3000I've been running the blu/brn/blu all winter with good luck and much better than stock. Engages 2650, great fuel mileage and holds rpm on top. Excellent trail spring, but jury is still decoding if it' a drag race winner???
Fleecer
- Jun 13, 2014
- 2019 SRX
Yup, 2650 and no bog either...it is smooth and subtle, yet still hauls the mail!! I ride my 2yr old around the house on Max Pump 17 with this setup. Works great....but there maybe better drag race setups.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
What about helix,is that stock too? Is this also on your max 17 tune.Dalton weights and stock rear spring.
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 nytro rtx, 2005 RS Vector MTN turbo
I think the blue brown blue would work very well also.Whats your take on the yamaha blue brown blue. Engagement is closer to the sidewinder stock spring but just slightly higher finish than with the blue white blue.
With the blue white blue primary spring I ran the secondary clutch with stock spring and helix
theewarrior
I have 270 hurricane and found the 33/35 helix hold back almost like Down shifting to far , 35/37 in now and like it
Apexed1
- Feb 9, 2015
- 2011 Apex XTX
What is the engagement RPM with the blue-white-blue primary spring?I think the blue brown blue would work very well also.
