Lasse Sjodin
Hello. Have an Apex 2011 and thought of changing the spring in the primary to original. When I unscrewed the lid, I really had to struggle to get it off. Noticed that the bushing was damaged on the inside and thought that was the reason why the cover was so hard to remove. Pressed in a new bushing but, the same phenomenon occurred when I was going to reassemble the cover. Extremely difficult to get on the shaft (without a spring) What do you think could have happened because this cover should slide easily on the shaft if I understood correctly. Thanks for the tips and advice. Thanks in advance.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Sometimes those bushings get a little deformed when you install them. Might need to hone it out a little.
shaft could have burr as well.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Is the primary clutch still on the sled?
If you haven’t removed the clutch bolt and the lock washer isn’t dead-nuts centred the bushing with be coming in contact with it and be very snug. Been there, done that.
Lasse Sjodin
You were absolutely right about the lock washer on the bolt. It was not 100% centered.Is the primary clutch still on the sled?
Thank you so much for your help, and I hope you have a great season.
//Lasse
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
No problem, glad I could help. Here’s hoping we all have a great season.You were absolutely right about the lock washer on the bolt. It was not 100% centered.
//Lasse
