MNBlizzard
I've never replaced these. My question is, do I need a puller to get the stock bearings out? I've removed the clips on the front and back of the bogey, pulled the wheel off and now the bearing is stuck on the shaft.
Once removed, how do I get them back on?
Grimm
You aint getting the bearings out.
You have to replace both wheel and bearing.
MNBlizzard
Ok, so how do I replace them?
Len Todd
It might help a bit if you told us which wheels you are dealing with. I am thinking they are the Upper Wheels by the rear Suspension-to-Tunnel Bolts. If yes, you probably want to reinstall the bolt in the shaft and use a puller. Sometimes you can hammer them off. But a puller works better.
MNBlizzard
Yes, I was working with the little upper wheels. I did get a puller and then pounded them back into place. Thanks!
