- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Well what started out as a red 136" Attak has now been upgraded.
-38" Ski Stance
-Excell Exhaust
-Hartman Inc 151" extension kit (tunnel & rails)
-8 tooth extrovert drivers
-2" x 151" Camoplast Series 4 track
-Slydog Skis
-Ulmer Racing modified clutching
The next step is to add a supercharger, but we'll make one trip to the mountains before we do that!
-38" Ski Stance
-Excell Exhaust
-Slydog Skis
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Looks good
Is that the ride you're taking to Muni next month?
Is that the ride you're taking to Muni next month?SRXSRULE
Allen, I'm going out the 15th-18th and the 27th - 1st of this month, We should hook up. Killer snow out there right now. I'm sure we can get that 151 buried up to the handle bars
===SRXSRULE===
KbxSrx
Looks good, are you coming to Revelstoke?
151 is a short track there now, isnt that insane?
LazyBastard
Why didn't you just start with an Apex Mountain and be done with it?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Mighty, probably won't be what I'll have in Muni, planning on bringing 2 short tracks.
Eric, I'll see what's going on. Swamped with work right now. I have 3 supercharger installations to do in the next 3 days, busy, busy, busy.
Kb, revelstoke, that's way too damn far away!
Lb, the customer didn't want a 162" track. He wants to be able to ride it in low and high elevation. He told us what he wanted, we built it from there!
LazyBastard
Well, with the curved rails on the 162, I'd have to say that your customer is lacking something up top.
freezie
did you say it started out red??
Alticity-Vector
I have had probs with the 2" track working under the attack skid. I haven't got it figured out yet but is feels like there is not enough room in the front to push the snow through the front heat exchanger. Might have to do 7 tooth drivers
:ORC So be ware of that. I am really disapointed with that aspect....
:ORC So be ware of that. I am really disapointed with that aspect....LazyBastard
Did you remove the heat exchanger protectors? Whatever drivers work for 2" track on mountain will work for 2" track on attak.
Alticity-Vector
Yes protectors are out.
When the track makes the turn over the drivers is the problem. I think.
When you get in deep snow the snow gets "trapped" in front of the drivers. There isn't enough roonm for it to displace the snow that hasn't left the track. Maybe holes in the track will help this???....
I have 8 tooth. Mtn. apexs have 9" and I bielieve a lower chaincase. There is only, maybe, an inch on the attack,at most as the drivers makes the turn in front of the exchangers. That is not allot. I can barely get my had in there!
LazyBastard
I cant say for the 06 RX1M, as it has a different tunnel, but 03-05 RX1M have the same tunnel as attak with the chaincase mounted at precisely the same location, and having 8 tooth drivers.
What precisely is it doing wrong?
Alticity-Vector
Well when you run it you can hear and feel a humming. Especially as you hit deeper snow. It just sounds like your trying to PUSH the snow. Loosing RPMs as you get in the deep.....
This just sounds like a track not cleaning the snow out from the rotation???? I am stumped....
Alticity-Vector
Huhhhh....derrrr....wellllll
I thought just for a look see I went out to look at my 8 tooth drivers. Somewhere along the way I got 9 tooths put on it!!! I have no idea how that happened because I had the 8s with the whole kit and just got one swappped somehow.
Anyways....problem solved. Thanks for trying to help out guys!!!
LazyBastard
Did I read that right? You have mixed 8 and 9's on it? That would definitely do bad things. LOL.
