Proper torque for Warrior primary
fourbarrel
Building a collection one sled at a time
New Brunswick
Canada
2019 SRX
I installed a heel clicker kit into a buds Warrior and never thought about the torque specs until I was putting the clutch back on so I used the same torque as my SRX 1st torque to 85ft lbs 2nd torque to 43ft lbs.Is this correct or should I take it off and do it again with another setting?
On a RX-1 # will be:
Tighten bolt to 112 ft lb
Loosen bolt again
Retighten bolt to 43 ft lb
1.5 full turns with impact.Back it off & then 1 full turn. Works for me! Happy Xmas Y,all!
rxrider, that 112lbs is a missprint in the manual, 85 is correct. in 03 some guys were breaking the bolt trying to torque to 112.
grader - Thanks for notifying me about the misprint, I was not aware of that. BTW I have never used a torque wrench to tighten. I do it much like Turk but I do not use power tools, I do it by hand. Works for me too.
Thanks for all the input guys I really appreciate it.
