RAMSOMAIR
Rock,
How about developing a push button start that mounts on the bars. The location for the keyswitch on these SW's is a PITA. With gloves on, its near impossible tucked up behind the window!
The electric start should be on the bars from factory like on a bike, the way God intended it to be!!!
I"ll buy 2 right off the hop.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Good idea
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I agree I always put my gloves on then realize crap I can't get to the key lolRock,
HighSpeedLowDrag
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 Apex GT 40th, 2008 nytro rtx, 2005 RS Vector MTN turbo, 2001 VMAX 600
Impossible to reach start switch? Do you even have an Apex?View attachment 125957 I use a sportbike handlebar mounted kill/start switch. The apex has an impossible to reach key location so you had to pull the kill switch and reach around for the key start.
budman 1000
- Jan 22, 2010
- Saskatchewan
The dealer asked how I liked my Sidewinder? I said I loved it and only 1 complaint- the ignition key position sucks as I have take my glove to get access to the key to turn it, it should be in a different position! the dealer thought I nuts for even suggesting such a thing. Good to know I'm not the only one thinking the same about the key.
Great idea Ramsomair
HighSpeedLowDrag
Sort of.
Is your Viperwinder even harder to reach?
The bike switch works very well.
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
- www.yamaheater.com
- 2007 Attak - LOVE my sled!!!
(I Replied to RAMSOMAIR via PM with this)
I agree & I like the idea!
I have a Cat also & believe it or not, IT IS WORSE than the SW!!!
Even Harder to get to & freezes overnight.
I HATE having to take my glove off to start my sled. Such a dumb idea...
Makes you wonder: Did someone even ride this sled & USE the switch (with SNOWMOBILE Gloves) prior to manufacturing?
Also have an Apex/Attak, that one is easy, nothing to using it. It is simple & it works even with big gloves on.
The Cat however, even has the key pointing straight up towards the sky without a cover.
(The Apex has a cover)
Sooooo, when it snows overnight after you park it, the snow melts from the rising engine heat and the water runs into the switch, by morning, the switch is frozen.
(Who would possibly think it would snow, on a snowmobile? Really weird, huh?)
How do you envision it working exactly?
Key left on?
Key off?
Thinking...
FYI Product suggestions sent to me via PM usually get more attention, as open posts aren't as worth the risk of expending R&D money & time on.
Key left on?
Key off?
Thinking...
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
Seems like a good idea, but only useful for stopping trail side. It's not going to help for when you start it for the first time or when you come out of an establishment. Both times you will need to reinsert your key. Also if it does not work from the On position what's to stop anyone from taking you sled with it in the Off position? I am thinking something like this:
You have your key in and in the On position. You stop for a few min trail side/gas station. You hit your kill switch. You reengage your kill switch. You press start button. Yes, No? Only thing is it would need to be mounted so that you aren't likely to hit it while riding or if you roll over or something.
RAMSOMAIR
Ski Doo uses a switch on the left bar to start sled/select RER. If Ski Doo can do it then Rock can make one better, I'm sure of it!!
budman 1000
- Jan 22, 2010
- Saskatchewan
Sidewinder key is very ackward to get at. So can you stop and start your apex from that bike switch?Sort of.
- Sauk Prairie, WI
- www.ty4stroke.com
This is a nice idea. I'll buy one. Start switch on the left hand bar, thumb operated.
I would also. Can even eliminate the key except for security since I have a tether I use all the time.
farmerschiferl
- Dec 28, 2010
- Hewitt,WI 54441
- 2017 Yamaha Sidewinder BTX-LE
- Hewitt, WI
I like the idea of this and also agreed the key on my BTX is a pain in the #*$&@ to get too. I would definitely be interested in one..Seems like a good idea, but only useful for stopping trail side. It's not going to help for when you start it for the first time or when you come out of an establishment. Both times you will need to reinsert your key. Also if it does not work from the On position what's to stop anyone from taking you sled with it in the Off position? I am thinking something like this:
Sent from my XT1650 using Tapatalk
Epicsw
- Sep 27, 2016
- Fort Atkinson
- 2017 Sidewinder
I'd have to agree with you. My Apex could always be started using the key with a gloved hand.Impossible to reach start switch? Do you even have an Apex?
Taking glove off to start SW... PITA and stupid!
