swmichvector
how to fix????????????
Roger
- Feb 10, 2007
- Osgoode Ontario Canada
- 2012 RS Venture GT (power steering doesn't work when real cold)
2006 Indy 500
Get some weight on your skis. Adjust the ski springs so they are shorter and/or adjust the front shock/spring in the rear suspension so it's longer.
Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
What do you have for runners? Doolies will push through corners. That's what mine had. Here what I have done with help from the guys on hear.
Went back to 6" single carbide, adjusted fron limiter strap down fron 1.5" of thread to 1.25 of thread showing. Shimmed my ski's by putting an old piece of hyfax 1"x1" under rear portion of ski post base on top of rubber pad( forcing the ski fronts upward to prevent Darting or tracking). My sled already has the 13mm sway bar link, Ohlins rear and 168 pics down the center. I saw an the best improvement on handling! I can run alot harder through the trails now! Do a search or go to the tech pages you will find the info! Good luck
Blue
Blue
swmichvector
i have the not enough 4" carbides that come when new. ( sled on has 150 miles) i will be getting 6 or 8 " and i will be studding before next winter. i will take a look at the limit strap. my old sled has viper suspension under it .this sled has the mono shock suspension and i have to learn how to mess with it.
wigyami
push
Adjust the transfers rod, so less threads are showing 2 lines from min. and put some Bergstrom Triplepoints, shim ski's and install ski savers
Indy
pushing I understand. You need ski pressure first, before you try anything. If you are pushing w/o studs, then you have NO ski pressure. Add better carbides, bergstrom with ski savers work well. Next is skis. If you must add studs, only use the minimum and up the middle only. Studs create more push.
twomorestrokes
You definitely need a lot more carbide. The originals are more like 3.5" and worthless. If you plan on studding, I would do it and put some good carbides on before you change all of the settings around trying to compensate for poor or no traction products. I like a lot of carbide (8" Woodys) instead of a lot of ski pressure. Just my preferrence as I don't like hard steering. I also don't like getting rid of all the weight transfer as it took Yamaha too long to get a skid that actually transferred. Life is more than just corners.
swmichvector
yeah , i am going to get 8" of carbide and some studs over the summer. i think i will just live with it until then. its really not that bad.
wigyami
push
While adjustment the transfer rod, it's easy to do and will get rid off that push.
Indy
swmichvector said:yeah , i am going to get 8" of carbide and some studs over the summer. i think i will just live with it until then. its really not that bad.
just loosen the spring on the front shock on the skid.
snoway
What sled do u have?
swmichvector
its a mono shock skid. it does not have the front spring.Indy said:swmichvector said:yeah , i am going to get 8" of carbide and some studs over the summer. i think i will just live with it until then. its really not that bad.
