Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Something to keep in mind if you ride in Quebec. I know that our 4 strokes are made to run on 10% ethanol so maybe 12% may not be so bad but for 2 strokes, this could kill them!
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Yes, we need to know the ethanol content of our fuels. Many of the stations I go tell me that their 91 octane gasolines have no ethanol in them. Unfortunately, some of the retailers of unbranded stations just don't seem to know. So, it's a buyer beware situation. Locally, it's generally easy to find this information, but on the trail in remote areas, some even unmanned fuel stops, you just don't know. Just another reason why I drive a 4-stroke sled.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Unfortunately, there is no ethanol free gas available anywhere in Canada anymore (Thanks Justin!), not even with 91 octane. And provinces are also moving towards 15%.
So Quebec is not the only one, Ontario is at 11% heading towards 15%. This is garbage! I remember back when I had my old Safari 377 and it started puking pistons. Come to find out they started adding 10% to 87 at the time so had to switch to 91. So all the two strokes will have to rejet to prevent leaning out their sleds. Come to think about it, injected 4 strokes, without an O2 sensor, won't be able to compensate and may also lean out, especially if we get to 15%. I think we can adjust the mix in diagnostic mode.
Mandatory ethanol content in Canadian gasoline is set by a combination of federal and provincial regulations. The overall requirement is not a fixed percentage at the pump but a target that fuel producers and importers must meet on an annual average.
Federal regulations
Canada's Clean Fuel Regulations, which replaced the previous Renewable Fuels Regulations in 2023, requires fuel suppliers to reduce the overall carbon intensity of fuels. While this does not set a specific volumetric percentage, ethanol is one of the main ways companies meet their reduction targets.
- Average renewable content: The previous regulations required an annual average of 5% renewable content in gasoline and 2% in diesel, which often resulted in a blend of E5 (5% ethanol).
- Fuel quality standards: Industry standards published by the Canadian General Standards Board (CGSB) permit the sale of gasoline with up to 10% ethanol (E10) across the country.
Provincial mandates
Several provinces have their own mandates that require higher ethanol content than the federal standard. These provincial rules are a key driver for the levels found at gas stations.
[th][td]Ontario[/td][td]Increases to 11% renewable content in gasoline for 2025.[/td][td]This will reach 15% by 2030.[/td] [td]Manitoba[/td][td]At least 10% ethanol content in gasoline.[/td][td]Suppliers must also blend 5% renewable content into diesel.[/td] [td]Quebec[/td][td]Requires 10% low-carbon fuel content, increasing to 15% by 2030. (Which is currently at 12%)[/td][td]This is part of its clean fuel regulations.[/td] [td]Alberta[/td][td]Minimum annual average of 5% renewable alcohol in gasoline.[/td][td]This is set by the province's Renewable Fuels Standard.[/td] [td]Saskatchewan[/td][td]7.5% ethanol mandate.[/td][td]The province also requires 2% renewable diesel content.[/td] [td]British Columbia[/td][td]Mandates 5% ethanol content in gasoline.[/td][td]This is in addition to the province's Low Carbon Fuel Standard.[/td]Province[/th][th]Ethanol Mandate (2025)[/th][th]Notes[/th]
The future of ethanol mandates
- Increasing blend levels: Driven by federal and provincial climate policies, the Canadian Fuels Association expects the industry to move toward higher ethanol blends, with a market average of 15% (E15) anticipated by 2030.
- Credit market approach: The federal Clean Fuel Regulations use a credit market to allow flexibility for fuel suppliers. They can meet reduction targets by adding more ethanol or by investing in other low-carbon technologies.
timmyz06
- Feb 28, 2018
- MTL
- switchback assault
Another goverment BS!!! Time to talk with TD!! I know Shell vpower doesnt have ethanol! Unless that changed!
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Nope. It also has ethanol:
forums.redflagdeals.com
The last holdouts were Costco and Drummonds Gas. We're hooped
Shell 91 now contains Ethanol - RedFlagDeals.com Forums
Beware. The days of non-filthy gas are over. With much sadness I noticed this new sticker at the Shell pump saying all gas contains up to 10% ethanol.
MK4TDI
- Jan 29, 2020
- Lloydminster Area SK,
- 2014 Summit XMX 800 154
2015 Summit XMX 800 146
2017 Sidewinder MTX162
Our Coop Refinery in Regina is ethanol free for the premium fuel only, basically covers all of Saskatchewan and parts of South Eastern Alberta. It was cheaper for the refinery to buy carbon credits than it was to put ethanol in the premium.Unfortunately, there is no ethanol free gas available anywhere in Canada anymore (Thanks Justin!), not even with 91 octane. And provinces are also moving towards 15%.
Not only that but 90% of the bulk fuel hauled to farm is premium now because the ethanol fuel does not store well long term.
The ethanol shouldn't hurt stock stoke 4 stroke sleds, but on the tuned ones it might catch up and cause some issues if the fuel system is close to 100% duty.
hydraulic yam
- Nov 12, 2025
- Mt Albert, Ont
- 2013 Apex XTX
93 Yamaha VKII, assorted fluid drive Yamahas
Buy Premium from a busy station , treat it with stabilizer so the ethanol doesn't separate
and still use it up in a few months is about as much as we can do . One sled company a few years back
suggested for summer storage to take out all fuel left in it , Fill with prem stabilized fuel and
remove that fuel before using the sled and put new stabilized fuel in again.
I have used up "old" fuel a couple gallons at a time when going to fill up your most tolerant
vehicle .. I usually use up in lawn tractor.
Canadian Native reserves often had zero ethanol fuels in all grades as they were not
forced to have it .. 100 ethanol is usually added to the delivery trucks when they
are loaded as it will eat the almn tanks.
Ron
Ron
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Unfortunately, no reserves around here. I sometimes go to North Bay. I'll ask my son to find out if they have ethanol in their fuel and if not, I'll bring a bunch of gas cans next time I go.
Skiduty
- Feb 5, 2024
- Iroquois, Ontario
- 2008 Yamaha Nytro, 03 MXZ 600, 02 MXZ 500F, 05 600SDI
How long has this been the case? I tested the supreme gas at local Ultramar and Esso stations maybe 2 years ago and neither ciontaimed any ethanolUnfortunately, there is no ethanol free gas available anywhere in Canada anymore (Thanks Justin!), not even with 91 octane. And provinces are also moving towards 15%.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
It was mandatory this last January. Costco here switched mid-2024. Drummonds was the last one when I filled up my Caprice in October 2024 before winter storage. Summer 2025 confirmed they also switched so my car is sleeping this winter with ethanol
www.canada.ca
What are the Clean Fuel Regulations? - Canada.ca
Ontario: the Cleaner Transportation Fuels regulation requires that fuel suppliers blend 10% of renewable content in gasoline from 2020 to 2024. The renewable content requirement increases to 11% in 2025, 13% in 2028, and 15% in 2030 and onwards. The renewable content must emit fewer greenhouse gas emissions than fossil gasoline on a lifecycle basis by 45% before 2030 and 50% from 2030 onward. The regulation also requires fuel suppliers to continue to blend 4% renewable content in diesel. This renewable content must emit 70% fewer greenhouse gas emissions than fossil diesel on a lifecycle basis.
Skiduty
- Feb 5, 2024
- Iroquois, Ontario
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
When you bought it, it was probably at a pump that sells multiple grades. More than likely the 1% is from what was in the hose before the premium pumped through. If you do test again, pump the first few litres into your car before filling your gas can.
If you do find ethanol free gas, I'll head down there with my cans. I'll use it for power equipment and when putting vehicles in storage. Which reminds me, I should pump out what I have in my lawn tractor.
Skiduty
- Feb 5, 2024
- Iroquois, Ontario
I will do some testing in the near future and post the results here because I need to know. If there is in fact ethanol in the premium fuel here now, I need to know and take some action to keep all my 2 strokes healthy. I haven’t researched yet, but there are some additives that counteract the ethanol?
Unfortunately I wish the 1 percent was from what was left in the hose but I already do as you mentioned. I always pump about 3 dollars into my vehicle before filling up my cans with premium. Then being the cheapskate I am, I usually fill my vehicle up from the same pump with 87 to get the rest of the supreme out of the hose, lol.
Skiduty
- Feb 5, 2024
- Iroquois, Ontario
idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
If you want non-ethanol fuel for storage, use Av-Gas. Doesn't need to be stabilized either.
