nards444
I had an 06 Nytro and the guy before had about 4-5 Red LED lights on the sled when I bought it. one on each a arm and two on each ide of the running the boards. I kind of liked them as if you were turned off at night you could flick those on and were fairly visible and gave you light to kind of see if you needed. He put them on that sled pretty good beyond caulking the whole entire wires on heat diffusers on the bottom of the footguard. I actually had to replace a light and they were 20 bucks peice. See if there is any set ups people are using that maybe fit the sled better and maybe more cost effective.
nards444
and dont want strips
mcamzr
Check out streetsourceled.com. I don't know about cost effective but I put them on a friends rev and they look and work great. Pretty durable too. He smashed the ones on the boards pretty go and they still work.
nards444
mcamzr said:Check out streetsourceled.com. I don't know about cost effective but I put them on a friends rev and they look and work great. Pretty durable too. He smashed the ones on the boards pretty go and they still work.
Yup thats what I had before. They were nice, but 165 bucks idk
wexfordhunter
- Feb 8, 2009
- Clawson, MI
- 2008 Apex LTX GT
2004 ViperS
- Clawson, MI
check britelites.net
Supa Dexta
Just picked up a kit on ebay from xk-led
CUSTOM MOTORCYCLE UNDERGLOW ACCENT NEON KIT 60LED
was what it was called... Water proof, and its a pretty complete kit for install... We'll see how they work out.
nards444
Supa Dexta said:Just picked up a kit on ebay from xk-led
Price and do you think neon lights will hold up to banging around like an LED would?
Supa Dexta
Its not neon.. Thats just describing the colors I think.. Its little pods with 6 led's in each..
40 bux? I think it was. I'd post the link, but I dont think thats allowed.. search ebay.
nards444
thanks
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
Bought all our LED's here:
http://www.superbrightleds.com/
Good prices and excellent quality LED's. - See Avatar
dylanjen9
I have pretty much the same kit as Supa Dexta and it works good.
Make sure that the lights are legal in your state. In Michigan you can not run with tinted headlights or underbody lights.
THKSNOW
Smooth Operator
- Aug 11, 2006
xtcman said:Make sure that the lights are legal in your state. In Michigan you can not run with tinted headlights or underbody lights.
You're right about the headlights... but I've run the "underbody" lights the past 3 years at night everywhere I ride (all over Michigan's U.P.), never been stopped. I'd like to see that law in print - got a link to back up what your saying (as it pertains to sleds -not automobiles)?
Supa Dexta
I started installing mine tonight.. Only thing I noticed was the 3m tape on the back wasnt going to be good enough.. I didnt have the heat on in the garage, which is part of the problem... So what I did was take some gasket maker and put a smear on the backside as well there is a tiny hole on the opposite end as the wire enters the light, that I figured should be sealed up.. Also put it on the switch to hold it in place.
I've used gasket maker before for similar things and it works great.. Gives them a little bit of flex, and a real good hold. With all the temp changes and moisture this will help to keep them mounted. And they are bright!
dylanjen9
You only have to worry if they can catch youxtcman said:Make sure that the lights are legal in your state. In Michigan you can not run with tinted headlights or underbody lights.
