ALL, PLEASE answer these questions honestly,briefly and in order. Thank you in advance. #1 Which aftermarket exhaust(not obnoxious but good sound) #2 Which clutch kit #3 Which shocks #4 What ONE ENGINE performance modifaction ( non turbo). This is what i am thinking for 05, #1 BENDER #2 ? #3 OHLINS #4 ECP KIT. PLEASE keep in mind that reliability is more important than performance but i am looking for both if possible.
Rx1 cowboy
love my bender pipe and ecp is definatly the way to go, although i have the loud pipe the quality is very high and sound is awsome, id imagine the quiet pipe sounds as good and is advertises to be the same soundlevels as stock, the bender pipes loses 9 lb on the quiet version.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
#1 White knuckle QC-1 from the people I've talked with plus you get an 11 lb weight loss.
#2 1st Remove the rivet in the heel of the stock weights to see what you think. Call Matt at the Speedshop and get Heavy hitters if you don't get results you like with the stock mod.
#3 I like my stock shock's.
#4 ECP without a doubt!
YamahaRx-Warrior
Ecp Kit, Whiteknuckle qc-1, Not sure on shocks but maybe you can swap your dealer for new ones for little money like ohlons.
Not sure on the clutch kit but you will love the ecp kit.
I get better fule milage riding side by side with my dad and alot better low end performance with no loss in top end.
How many miles do you have on your sled now?
Thank you all that have responded, keep the posts coming. YAMAHARX-WARRIOR, at this point i have 12,002 miles, and should end up with approx. 12,500 for this season.
POWERHAULIC
Bender exhaust
Stock weights (lighter)
Ohlins
Leave it alone or turbo
Ohlins
Any more thoughts on this subject?
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
#1 - According to my bud who was at Bender's a couple of weeks ago, I'd wait to see what he has this summer......he's supposed to have the "switchable" exhaust ready by then.
#2 - Stage 2 kit from Matt at the SPeedShop
#3 - If you're only replacing shocks, then I'd say Ohlins
#4 - ECP Filter kit
Buddah
#4 - ECP Filter kit
Buddah
POWERHAULIC
My opinion has not changed. 8)
- 7K
- 6K
