Racy2
- Mar 16, 2005
- Toronto, Ontario
- 2022 Sidewinder SRX LE
snoway said:I been called a parade pisser .
many others to see where the ape wins.
http://www.youtube.com/watch?v=K2fGHn2xLQE
I raced the XP through the gun at 660 ft. The XP did 72 MPH and my Apex did 93 MPH.
Go Figure......
SledFreak
- Feb 7, 2005
- Ontario. Canada
Good job..
TB151
This past weekend was spent riding in Maine with a group of friends. Sleds included a 2003(4) ZR 900 , Ported 2005 MXZ 800, 2007 MXZ 600, 2002 XCR 600 and finally a new Rev XP 800.
Buddy with the Rev wanted to race very badly. Firt run on the lake from a start, I took him off the line and stayed about 2 sled lengths in front until about 90 when i would start to steadily pull away.. CYA
Next run, from a 30 MPH roll. Pretty even up until 90 and again, pulled away.
The ZR 900 was also very quick and would stay with the XP and I until about 70 when we would walk away.
Both the XP and my Apex have studs, although I only have 96 and was spinning quite a bit off the line. Also, I was only pulling 10,500 rpms, when i normall do 10,850 or so. Not sure why i wasnt pulling the rpms this weekend. The dealer said that as the motors break in (im at 1650 miles) the torque and power increases and u sometimes need to go to a stiffer clutch spring.
Regardless, the sleds are fairly equal in power, except on top end when Apex wins
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
This weekend the Nordic dragracing championships were held in Sweden. In the stock 800 class Yamaha SRX 700 took 1st, 2nd, 3rd and 5th place, not a XP to bee seen on top of the list, go figure. Maybe the XPs are not as fast as the doo guys like to believe.
Yamaholic22
TB151 said:This past weekend was spent riding in Maine with a group of friends. Sleds included a 2003(4) ZR 900 , Ported 2005 MXZ 800, 2007 MXZ 600, 2002 XCR 600 and finally a new Rev XP 800.
Going to a stiffer (higher rate) primary spring is the wrong way if you are making more power. The primary spring, along with the flyweights and rollers, controls and varies the amount of load being applied to the engine through the rpm range. The primary spring resists the upshift (loading) of the flyweights. If an engine is making more power, it can pull more load without being pulled off of peak power. Thus, a softer primary spring can be used to produce a faster upshift without bogging the engine.
Also, please include your location in your profile. Site rules.
tttario
Yamaholic22 said:Also, please include your location in your profile. Site rules.
LMFAO!!!!! Where is yours?????
stoutner
- Dec 6, 2005
- Seneca Falls, NY
- www.ecsexpress.com
mbarryracing said:Wayne, so what broke on that goat? The wrist pin or old rod bolts?
Maybe that XP needs a turbo?
Well, I'm embarrased to say I made two really minor mistakes.
Mistake #1: I forgot to install the oil dipstick guide in the oil pan. Therefore, I could not check oil level properly or install oil dipstick all the way in. Also, Oil was being spit out of dispstick tube because dipstick was not in.
Mistake #2: I didn't have gauges...just the idiot lights. I switched the wires by mistake on the oil pressure light and the alternator light. In other words oil pressure sensor was hooked to alternator light.
Anywho: I was driving down the road, unknowingly low on oil. All of the sudden, my alternator light came on (which was actually my oil pressure) and the engine started running a little rough (Probably the hydraulic lifters not getting enough oil pressure). I thought my alternator wasn't charging and didn't have any electric so, I hammered the throttle to the floor and was doing about 90mph and then...BOOM
I got out of my car and saw this baseball sized hole in my oil pan and a small flame coming out of the hole...It was a pretty sad day.
Prior to blowing it up, I whipped a 496 Chevelle, a 440 SuperBee a couple of souped up Nova's and some other hot rods. It was fast for a day or two though !
Yamaholic22
tttario said:Yamaholic22 said:Also, please include your location in your profile. Site rules.
LMFAO!!!!! Where is yours?????![]()
LOL!!!!!! Wow do I feel a bit sheepish "BAAAAAAAAAAAAAAAhhhhhhhhhhhh" Let me go hide under a rock now....LOL!
stoutner
- Dec 6, 2005
- Seneca Falls, NY
Yamaholic22 said:tttario said:Yamaholic22 said:Also, please include your location in your profile. Site rules.
LOL!!!!!! Wow do I feel a bit sheepish "BAAAAAAAAAAAAAAAhhhhhhhhhhhh" Let me go hide under a rock now....LOL!![]()
YOU ARE SO BUSTED...LOL
vmax80096
I've raced 3 800xps. Two were the 137 and they weren't in the running and the 3rd was a 120 with 1.25 on it, he had the jump on me, 2 lengths out of the gate and that was where he stayed until about the 1000ft mark then I would go by at a walking pace. Is that realistic definitely. Stock apex has 150 hp and weighs at least 150 lbs more and is 3hp less than the skidoo. Knapp must have an exceptional attack, bone stock and beating all these xp skidoos and 1000 cats that weigh the same and making at least 15hp more. On snow you can have a sled with stock clutching close and another with bang on clutching and you might see 3 lengths difference, expecially with the 4stroke. Do a 1000ft run and have it clutched at 10500 or 10700 and you will see at most 2 lengths difference. Only big differences you are going to see on snow is if one sled has better traction over the other. If anyone would like to offer me advice on how to make mine faster I'm all ears. I have the Ulmer airbox mod, ignition controller, PCMIII, which I"m told is only good for 3hp total and runs 10000 out of the gate and runs at 10700 at the 1000ft mark. Can I beat a 1000 mach, no, why, because sleds weigh the same and he has close to 15hp more than me.
SledFreak
- Feb 7, 2005
- Ontario. Canada
apex06, what gearing/clutching to you have. You running the stock track or did you switch to the cobra? Any studs? If so what size?
vmax80096
That was with stock clutching coming out at 9800 and running up to 10700. Also running the ripsaw on so so hardpack. I now have the cobra on and running Ulmer fuel controller and ign module. If I had all ths done before probably would have stayed even with him right from the start and started to pull away sooner. The 800's don't seem to have much after 100mph. Neither of us had studs and both running the same track.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
apex06 said:I've raced 3 800xps. Two were the 137 and they weren't in the running and the 3rd was a 120 with 1.25 on it, he had the jump on me, 2 lengths out of the gate and that was where he stayed until about the 1000ft mark then I would go by at a walking pace. Is that realistic definitely. Stock apex has 150 hp and weighs at least 150 lbs more and is 3hp less than the skidoo. Knapp must have an exceptional attack, bone stock and beating all these xp skidoos and 1000 cats that weigh the same and making at least 15hp more. On snow you can have a sled with stock clutching close and another with bang on clutching and you might see 3 lengths difference, expecially with the 4stroke. Do a 1000ft run and have it clutched at 10500 or 10700 and you will see at most 2 lengths difference. Only big differences you are going to see on snow is if one sled has better traction over the other. If anyone would like to offer me advice on how to make mine faster I'm all ears. I have the Ulmer airbox mod, ignition controller, PCMIII, which I"m told is only good for 3hp total and runs 10000 out of the gate and runs at 10700 at the 1000ft mark. Can I beat a 1000 mach, no, why, because sleds weigh the same and he has close to 15hp more than me.
Couple things that I believe makes mine fast. And a couple things that you pointed out that may be holding yours back.
I'm using a 23/40 gear to get it rev higher sooner with the stock clutching.
Also multiplies tq. to front drive. Mine will run 10,500 out of the hole and climb to 11,000 using the stock clutching. When I put in the Pro-Line/Dalton setup it will come out at 10,700 and climb to 10,800 and accelerate even harder then stock.
I also run the Ski-Doo 137" Iceripper XT ,sharp stud, single ply track. It weighs the same as the stock track. I don't have to swing all the stud weight around and it hooks decent and won't give up 5 MPH to a track with 144 studs in it.
I also make sure to keep the engine cool, and cool air going into the stock airbox. I tried the mod airbox and found it inconsistent at different points in the powerband. The little bit of added power at wide open throttle was not worth the upper midrange loss. I think it looses some ramming effect due to reduced pulsation at certain RPM and frequencies. Mine was quicker with a stock box.
I'm not so sure about the F1000. They weigh only slightly less than our Yamaha's, make 10 more HP than an Apex, and have a narrower powerband. Now you take and stud the F1000 and that will slow it down enough for the Yamaha to get around it.
The XP 800's I've run, have not even been close, which has been quite surprising. I'm sure the doo-boys will get it figured out next year.
Overall though, the fourstroke RX-1/Apex runs real strong after they are well broke in. It takes a lot of miles though. Like over 2000 miles to fully take advantage of them.
Running the stocker this year has been a lot of fun. It really surprises the two-stroke guys. When I ran the turbos in the past, after you raced someone once, they never wanted to race again. It's exciting again.
