jonnytro
i bought the excel 6 wheel kit i was wondering if the rials will crack. an if u have this kit plz let me no how it is
tandyammy
- Nov 8, 2010
I bought a set two weeks ago, put them in and have notice that the sled rolls easier. I rode on Friday 20 miles and Sunday 40 miles never smelled the slides burning off. I put it in the heated garage did not see any rail crack issues. I have an XTX so i got the 8 wheel kit. There using the stock yamaha mounts and holes so i don't for see an issue.
Rayman5271
- Oct 3, 2009
- Northern Maine
- 2016 Yamaha SR Viper XTX SE
no issues... if your going to crack a rail, your going to crack a rail.
mach9
Rayman5271 said:no issues... if your going to crack a rail, your going to crack a rail.
X2 no issues.
Been running Doo wheels for 2 seasons.
sleddingfarmer
mach9 said:Rayman5271 said:no issues... if your going to crack a rail, your going to crack a rail.
X2 no issues.
X3
jonnytro
some people r say that with the bigger wheels ur going to crack a rail but i don't c it being any different from stock like u said if there going to crack there going to crack
i would like to here from people how many mils they have on them. i no i am going to like them. going up this weekend cant wait to try them out
jonnytro
what size r the doo wheels compared to stock
Rayman5271
- Oct 3, 2009
- Northern Maine
135mm vs 129.5mm if I can remember that far back...
grizzerly
crcked rail
I put on skidoo wheels start of year and i have a crack on left rail above center wheel bolt. Unsure why? 2009 xtx, no studs
Rayman5271
- Oct 3, 2009
- Northern Maine
Rails crack... doubtful the 3.25 mm from center to edge would cause enough added stress to crack the rails. My take and most others will agree... if you hit something with the stock idlers just right you will crack the rails just the same as you would with the larger idlers. This will probably be one of the better upgrades you do. Sled will roll better, minimal hyfax wear, more speed... I wish ulmer had the kit when I was engineering my own. I ended up using skidoo two hole mounts and polaris idlers... 1100miles later on two machines... A+
T T Bone
Bullsh..!
Why would Excell performance after over a year of testing sell a product that will cause damage instead of preventing damage Who told you the larger wheels will cause cracking in the rails and why?
garyw
wheels
Got 5033 miles on my 09 fx with bomb.135mm wheels with no problems.Hyfax wear almost doesn't exist.May switch to excel wheels in a couple of weeks just because they look better.
jonnytro
kevin from portwashington said that the rails will crack with the bigger wheels because it will put more stress on the rails but what i didnt understand is that hyfax will ware no matter what to the wheels so it only makes sense to put bigger wheels on.
Rayman5271
- Oct 3, 2009
- Northern Maine
Well he is wrong... if they crack chances are you hit something that would have cracked them with normal idlers.
jonnytro
Rayman5271 said:Well he is wrong... if they crack chances are you hit something that would have cracked them with normal idlers.
i agree with u but i wanted to now what every1 els thought
another thing i dont unerstand is y doesnt yamaha do this in the first place
