thunderbolt
I have a 2011 apex se 128 track it seems the clearance between the track and the tunnel is very close . Has anybody tried raising their tunnel with some sort of relocation brackets , if so what changes did you do with the steering etc...
vx700xtc
Do you plan to run studs? If not, remove all of the tunnel/ heat exchanger protectors, then there is plenty of room. Changing the skid location will mess with suspension geometry big time.
