equillibrium88
- Jan 18, 2010
- North Bay Ontario
- 2007 Phazer GT
Just wondering if anybody has some decent tips on re-installing the rear axle. I had the skid out (first time job for me) to replace bushings and send my shocks out for rebuild. The skid was a bit of a pain to get back into the tunnel but did so easily with the rear axle and wheels removed. Now I can't get the bugger back in.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
A second set of hands helps me a lot. Make sure you pust all the slack of the track to the back to allow room for the wheels.
Also make sure that you figure out what way the track tension adjusters go before pushing the axle through. They are at an angle and if you have it turned the wrong way the track will be in the way when you go to tighten the track.
Other then that I don't have any tricks, maybe compressing the skid would help with getting more room to line everything up.
equillibrium88
- Jan 18, 2010
- North Bay Ontario
- 2007 Phazer GT
Thanks for the info, appreciate it.
nswsparky
- Oct 2, 2011
- North Shore, MN
- www.nsw4x4.com
- Phazer
did you unclip the coil spring from the wheels.
xrrider
Also, loosen the two bolts that hold the rear scissor arm to the rails just a little so you can flex the rails out. Makes it easier to get the wheels,spacers and washers in between the rails easier. Just don't forget to tighten them back up.
