WarriorBeads
- Dec 4, 2005
- Peterborough, Ontario, Canada
- 2004 Rx Warrior
Use the Yammy heat exchangers.... I have the RX Mountain exchanger on my Warrior and the RX/RS shortie exchanger on the g/f's Vector.
The shorties are a quick install (a little driling/cutting) but no big deal - and no protector is required....once you see it intalled, you'll see why.
As for the Warrior, similar install BUT, you'll need a tunel protector extension IF you're studded....Yamaha DOES NOT make one, as this protector was originally designed for the Mountain version.
PM JDMCRX if you aren't handy with aluminum welding..... If you are good at basic fabrication, I can send you some dimensions and angles of mine, which are really based on his design anyway. PM me if you like.
