Rear hose cover on Attack ?
apexer
NE PA
I was wondering I was missing a screw on the rear hose cover on the tunnel. I took it off and found that the one clip was missing where screw was missing looked like it was pulled throuh the plastic during install. Also same clip on the other side, the middle clip towards the rear of the sled was pulled through the plastic and not holding. I don't think this is the dealers fault it was probably done at the factory during install or does the dealer install this peice? Just wanted to know if anyone else has seen this. I also have a stripped screw on the collar under the bars. I know others had the screw on the collar stripped just wondering if anyone had a problem with this cover. This is on an Attack not an Apex.
The cover you are talking about is not put on by the factory.Take it back to your dealer. It is their fault.
