JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
(Background, had the skid out this fall, re-greased everything, shocks rebuilt as well and had the suspension setup by a suspension pro. RR upper shaft installed too.)
On my '17 R-TX-SE I noticed today while getting gas after riding some very rough trails in Cochrane aggressively fast that my snow flap was very close to toughing the ground probbaly half way compared to normal. I pushed down on the rear and there was still some travel and rebound but only to the same halfway point. If I pulled up on the rear there was about 4-5 inches of sag to gain. When I had the sled setup we did 3" of sag total with me sitting on the machine.
I tried my torsion springs on 3, still no difference which is weird as the torsion springs should set my ride height/sag.
All appears to look normal under there, I thought I had a blown rear shock but my shock guy said it wouldn't really help hold the rear up at all.
For all intents and purposes, it's riding great still, and these trails are ROUGH! Sometimes when I came to a stop it is at the top as it should but most times it's in that half way down position.
Any advice? I can take a video in the morning
vmxrdr
- Feb 3, 2012
Crappy luck for your ride, buddies told us it got crazy rough over to Hearst. Unless something broke in your skid sounds like you may have lost your gas charge in shock? Or at least part of it. You mentioned fresh overhaul on shocks which should have prevented that.
Hopefully you can finish ride okay.
JayM
- Oct 29, 2018
- Pickering, ON
Smooth Rock Falls to Cochrane was 50km of huge moguls, it as terrible, never seen worse!
I'm going to monitor again today and take pics and post an update. I will take the skid out when I get home and check it all out and have the shocks looked at too.
Pstn head
Check it on a flat surface like concrete or asphalt. That'll give you a better idea of what's going on.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Glad I didn’t head up there this weekend. Hope you figure out what’s going on.Smooth Rock Falls to Cochrane was 50km of huge moguls, it as terrible, never seen worse!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Blown shock seal?
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I have the same issues at times with both my previous Apex , even with the Star kit , and now with the SW.Glad I didn’t head up there this weekend. Hope you figure out what’s going on.
Just ordered the 5 sided cam adjuster from Star , and am going to drop the sled off at my shock guy , who serviced the shocks late ly.
WinterWolf
- Mar 25, 2017
- Connecticut
Sometimes it gets so loaded with snow and ice and that can compress it down some...especially after hammering on it through the rough. I’ve seen this in my Apex and previous sleds. So far haven’t really seen it on my Winder. I know it’s a simple idea..but sometimes thats all it is...especially if it’s still riding Fine as you say.
JayM
- Oct 29, 2018
- Pickering, ON
So I rode 250km today, I even put my torsion springs back on 2 and it rode amazing. Half the time I stopped it was "sagged down" a bunch and the other half it was fine. And it was pretty much all flat terrain, so weird.
WinterWolf
- Mar 25, 2017
- Connecticut
Honestly I think it’s the snow and ice in there that sometimes seems to compress it some...?
Fleecer
- Jun 13, 2014
- 2019 SRX
This is odd for sure. Do you have the rear coupler blocks and/or rod removed?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Frozen shock??
JayM
- Oct 29, 2018
- Pickering, ON
Another 200km this morning before heading home and I put the Torsions back to 1 (that's where we had them when I had the suspension setup) and she rode like a dream! Still half and half with the rear sag. Got home late so this week will pull thr skid and check things out and report back.
I have a few posts I need to make this week too, on the Elka Dual springs I had out on my revalved SE front and middle shocks amd on the CV-Tech PB80 I installed for this season. Have 1500km on them now this season so have a good grasp on how it is compared to stock.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I bet Cochrane was crazy this weekend eh!!
Trail around here(Sudbury area) should be opening this week with all the snow in forcast
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I trailered toI bet Cochrane was crazy this weekend eh!!
first 3rd of the trail was rough , but from this point on almost all fresh groomed .
Passed a groomer on the red part , should be a lot of trails open this week .
