Rear Shock rebuild and susp setup
351wford
Canada
Canada
Crosstour 9000
Hey guys My rear track shock is Fox Float 2 but always loose it's pressure after a week or when hard rinding it , it just dont last the day... Anybody know what seal kit should I order to repair it?
Also while Im here
What shock pressure would u guys recomend for it for boondocking off trails (2014 crosstour 141 2.25 track 9000) and im about 175lbs
rear track fox float 2
front track coilover
front skis are coil overs
thanks
Also while Im here
thanks
Talk to @cannondale27 about the shock loosing air, floats will change by about 5 lbs setting in a warm shop and then going out in the cold. What sled is this on? We may want to move this into a Forum specific to your model.
Ive tried it outside and inside with the sled jacked up from the ground.
My sled ia a 2014 crosstour 9000 (1100 turbo 2 cylinder suzuki)
So basically this is like a Yamaha 141 XTX Skid. Hit up @cannondale27 about the rebuilding idea and then maybe hit up @NOS-PRO about float riding pressures.
