I started my 08 Apex RTX today. When I moved it this piece of metal came out from under the suspension. I believe it is the top of the front shock absorber of the rear suspension. I believe it holds the coil spring down/in place. Can someone help me out? Is there a retaining clip that holds it too? I only found this piece on the ground, see pic. As well, di I have to remove the shock absorber to put in back in place? Can I just drop the shcok and push absorber down and put clip back? I sure hope it isn't a dealer fix. Please help?
