vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
I got spacers for xtx let me if interested brand new
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
lots of little issues with sag and they all help a little bit but, no miracle cure. all the above suggestions help a little bit but, there is no cure.
I did have an issue with mine that hasn't been addresses and thought I would add it to the list. I bent the lower shaft on the double transfer rod both stock and also with the star suspension kit installed......caused by having too much fun I guess
I had Hygear revalve and rebuild my shocks this year. They lasted for roughly 700 miles. The keeper on the front shock spring got destroyed within 500 miles. They sent me new ones. Then went out after I fixed the front shock and blew the canister out of the rear shock. Literally looked like someone stuck a stick of dynamite in the canister. Called Hygear. Wouldn't help with anything. Go with Star Suspensions. Maybe they will stand behind their product
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
just as info.....rebuild only includes oil change and replacement of internal wearable items unless agreed to by hygear/owner and does not include a warrantee on the structural integrity of shock parts. and re-vale is simply changing / modifying of valve stacks & shims.
nice of hygear to send you spring keeper, and blown canister is not their problem either.
