Lashcat
I put aluminum upper idlers on mine but I had to have them machined so I could put the right bearing in them.
http://s1203.photobucket.com/albums/bb3 ... 0_1278.jpg
Wow nice!
Grunter
Update on wheel mod
12/12/12 -> Works perfect! no issues, no shenanigans(wheel freezing due to ice locking on the hole), no flat spots, no failure - just the way it should of been from the start!
cannondale27 said:Thanks Grunter.Looks like your solution is best out there till someone decides to make a wheel for us.
farmerschiferl
- Dec 28, 2010
- Hewitt,WI 54441
- 2017 Yamaha Sidewinder BTX-LE
- Hewitt, WI
yamaha does make wheels to fit our machines with a rubber edge
http://www.yamaha-motor.com/sport/acces ... 007/1.aspx
Upper wheels?
farmerschiferl
- Dec 28, 2010
- Hewitt,WI 54441
- Hewitt, WI
cannondale27 said:Upper wheels?
i do believe so, ill let you know when i change them this weekend when skids out to install freeride track
Thanks!I think you will be impressed with the track.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
cannondale27 said:Thanks!I think you will be impressed with the track.
Good to hear, I just installed one today.
equillibrium88
- Jan 18, 2010
- North Bay Ontario
- 2007 Phazer GT
I own a 2007 Pazer GT.
I just replaced the upper idler wheels this July.
The FX model of the same year used a solid white wheel. White being stronger then black since they lack the dye which weakens the plastic. The GT came with spoked black.
Why they would do that I have no idea.
since then the GT model has had a revision with this part and although the wheel is not white it is now solid and black, with a small hole to enable access to the shock mount.
They seem stronger then the spoked model since the spokes where thin and allowed to much wheel flex especially when riding hard on twisty trails. The new ones are a lot nicer in that regard but come at a hefty $80 CND each.
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Previous sleds: 1996 Vmax600, 2007 Phazer, 2016 Bearcat 3000
Does the skid have to be out of the sled to replace these wheels or can it be done still installed?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
You have to drop the rear bolts at least, so 1/2 way out3wheelerdude said:Does the skid have to be out of the sled to replace these wheels or can it be done still installed?
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
canoehead said:You have to drop the rear bolts at least, so 1/2 way out3wheelerdude said:Does the skid have to be out of the sled to replace these wheels or can it be done still installed?![]()
OK, but the front mounting bolts can stay? So the skid remains in the track?
canoehead
- Jan 14, 2011
- NE, Alberta
That's correct, just unload your torsion springs (from the idler wheels on rails) and remove rear bolts and it should swing down far enough. I would recommend you just loosen front bolts to aid this and prevent binding. I put on Hygear spacers on the wifes Phazer using this method.3wheelerdude said:canoehead said:You have to drop the rear bolts at least, so 1/2 way out3wheelerdude said:Does the skid have to be out of the sled to replace these wheels or can it be done still installed?![]()
pat lynch
- Nov 19, 2014
- Yamaha phazer rtx 2009
Any more advice on replacing the wheel.....I'm doing it this weekend and would appreciate any additional tipsThat's correct, just unload your torsion springs (from the idler wheels on rails) and remove rear bolts and it should swing down far enough. I would recommend you just loosen front bolts to aid this and prevent binding. I put on Hygear spacers on the wifes Phazer using this method.
Have you read the faq sticky at top of Phazer forum?
http://www.ty4stroke.com/threads/replacement-upper-guide-wheels.122825/#post-1094208
