FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Here's the fuse and relay layout.So it is the fuse (relay) in the box?
I've thought about placing a direct to battery, switched hand warmer element on top of the
relays. Conduction is better than convection! But I'm not sure if the time it would take, to warm up the relays, would drain the battery too much to start the machine?
I've only had one no start due to a stuck relay. Pretty embarrassing when riding with a group of SkiDoos.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
So the "fuel pump" relay is what I can take out to bring inside and keep warm...
Yes or since you relocated now you can just pull it if there is a issue.So the "fuel pump" relay is what I can take out to bring inside and keep warm...
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Perfect. Thanks for the clarification cannondale!
klondike22
Great dea...I just moved mine today....took all of 10 minutes!! Now have good access to fuse block as you have said. Many Thankx!
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
I haven't even tried bringing the relay inside to see if it'll make a difference starting..
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
If that's the plan you should also pull the ISC relay. Both relays need to be working for the engine to start.
Turnerrd
Has any one seen any ill effects from putting the fuse box on its side? Fuses or relays falling out/loose, water getting in? Does anyone make a bracket to keep it upright on top of the belt guard?
I've got 3 Vipers to do and (2) 7000s.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I've had no problem with the box mounted on it's side so far.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Almost 4000km, no issues...
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
Mounting on the side directly to the belt guard makes me nervous. Some have stated no problems is so many miles. I have a feeling the odds are in their favor. A blown belt could change their mind.
The Barn of Parts bracket is a very nice quality piece.
http://www.barnofparts.com/viper-fuse-box-relocate-kit
Easy to install, isolates from the belt guard, and holds the fuse block in the proper position.
And it seconds as a great spare belt storage option.
In my opinion, it's too nice of a sled to do it any other way. Cheers.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Awesome idea!!!! I wish I would have read this thread a week ago when troubleshooting fan!!!
This one is for sure on my next "to do list"
thank you greatly for sharing!!
Goober01
- Jan 5, 2017
- Galesville wi
- Viper
- Galesville wi
Nice jobHey guys finally had a chance to take sled apart for spring clean up. Want to show you how I relocated the fuse box.
Zoggan
I'm going to move mine. It looks like a very simple project, and one that I'll be thankful I did should I need to access it. As soon as someone posts a photo of a mangled wiring harness I MAY consider spending more than the $.00 it costs to do this mod. (the rivets are in my cabinet already )
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
