yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Just a heads up!
Make sure to remove your primary rollers and inspect.
Just spinning them in place on clutch will not necessarily show wear!! They may seem like they roll true but might be hanging up on the spacers.
Perferct example is this ones!! Just spinning them while in installed in primary they felt perfect and smooth
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Yes I have been in the Same situation.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Thanks for the heads up..
SPM
- Nov 18, 2018
- so. mn
- 2018 Sidewinder L-TX LE
Great advice! I inspect the rollers often and replace them every season. Cheap insurance IMO.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I pulled the weights out to check to bushings and look at this!!!!
Bushings in weights were totally shot and one weights was cracked and fell apart when removing.
My guess is is since rollers were shot it put excess pressure to the one side of weight bushing causing it to wear. The one side of the spider is grooved from the weight making contact!!
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
How many miles on this sled Marc? Is it tuned?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
This is why I always check my clutches over every week.
Hope fully my roller problems will be behind me this year.
Nice find!
Nice find!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
8000km!!How many miles on this sled Marc? Is it tuned?
This sled hasn't been maintained by the previous owner!!! It has a 225 pefi tune
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
That could have been very bad!
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX (on order)
2018 High Country 9000
2001 SRX 700
My sidewinder primary started to eat rollers bushings pretty bad last year. It started with a 600km ride with new rollers bushings and they were completely shot like yours when back home.
Last set of roller bushing lasted around 100km.
So I ended the season with an old style primary without any problem. Will have the sidewinder primary rebuild this winter and hope to have it run good again. Mine dosent bind like some, but now the play in it seem to cause an harmonic that make the roller bushings to wear in a phenomenal time.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Maybe I am wrong, how would you not notice the rubbing of the spider? I think a lot of us would feel and hear that. Lucky catch there.
Alsim
- Oct 6, 2014
- LTX SE 2018
You defused a bomb!!!8000km!!
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
Just a added note. When you remove the roller buff them on a buffing wheel. do the the shaft also.
If they are in good shape the will look like new
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
This is why maintenance is so important!
Thunder Products Clutching has received over 200 clutches just this fall and a good portion of these clutches were in poor condition, ready to either explode or jam up. We are happy that people are putting trust in us to go through their clutches as most do not know what to check for. I am taking pics of all the issues I have seen and logging data on miles, brand of clutches, belts used and clutching combinations.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Keep an eye on the movable sheave on a team clutch for cracking!!! I found 4 this season (2This is why maintenance is so important!
Stock ,2.tuned) plus mine.
After 3 months of arguing with cat and dealer I am getting a new clutch under warranty.
