thetruck454
When should I replace the springs in my primary and secondary clutches? I just got the clutch kit from Ulmer and it retains the stock spring in the secondary on xtx sleds. I have 3k miles on the sled so I wanted to know if I should replace the secondary spring while it's apart or if it will last for 6k+ miles and I'll bet set.
2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
Im sure it will last but they are cheap enough i would just replace it while your doing it.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
I would replace so when you try the clutch kit you know all the springs are new because the old will have a sag to it so it best to start with new and it will be better to find tune the clutch kit that my recombination.
thetruck454
Ok say I replace it with a new one. Does this mean I have to keep replacing springs every couple thousand miles?
darv
- Aug 9, 2005
- 08 Apex 40th LTX
no but they should be changed every few years to get the best performance out of the sled.
