SIKEWARD
I have a 14 Viper short track. My wife rides the sled and she complains that it is darty. What skies can I put on it so it is a nice easy handling machine with proper trail manners?
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
cat skis..cheap fix
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Put a set of Woody's Slim Jims on and shim the back of the skis. Ive had good luck with that and cheaper than new skis.
Yes 14's had the Cat ski's so a dually carbide works real well.
Katannilik1
- Jan 14, 2015
- Kimmirut
- 2005 VK540, 2010 VKPro, 2014 Viper
Check ski alignment. Straight alignment "darty", toed in "really really darty". Toed out it will ride like a Lincoln. Measure along wear bars not the ski's
rbell14
Love my curve skis with dually slim jims. Holds like a train on rails now!
Steve Wright
- Oct 17, 2014
- Omemee
- 2014 Yamaha SRViper L-TX SE
Bergstrom Skegs will fix the problem. I had them on my Viper last year. This year for something different I put on a set of C&A XPT skis with Bergstrom skegs
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
The 14 RT-X came with Cat skis which are a very good ski, nice starting point.I have a 14 Viper short track. My wife rides the sled and she complains that it is darty. What skies can I put on it so it is a nice easy handling machine with proper trail manners?
I would begin with the Cobra carbides in a length adequate for her riding style. Heavy ski pressure and miss-alignment of the ski will also cause extreme darting depending on snow conditions. I find many riders tend to run heavy on the front skies, probably unknowingly set that way from dealer giving a rail like feel in the corners sometimes a little tippy but very uncomfortable in a straight line or while on engine brake into a corner. Heavy ski pressure will dart, just how much depends on many factors. I would start with ski pressure, ride height and alignment. Then install a good carbide see what changes then adjust accordingly. Skies alone in most cases will not solve a darting issue. After everything is all set up perfect some occasional darting may occur, after all the surface in which we ride is ever changing and only seat-time can help. https://www.qualipieces.com/cobra#_...rderBy:null&IsDescOrder:false&Index:0&Count:0
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I actually have a good used set of cobras if you want to try them.
If you opt for a dual skag, you want woody's slim jims....not woody's dooley. Both eliminate darting, but the slim jim offers much more precise handling over a dooley. You will get more push with a dooley.
Beings its your wife, perhaps you want to look into snowtrackers as they also give the sled a lighter steering. Snow trackers are are my first choice for runners on single keel skis. Excellent handling, no darting. self sharpening carbide, and lighter steering. I think I still have a demo set from last year that only have around 200 miles on them.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Snowtrackers
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
Snowtrackers
I agree 100%. I know I sound like a broken record, being such a fan of the Snow Trackers, but I have Cat skis with semi-aggressive Snow Trackers on my 2015 LTX, and my riding buddy was so impressed that he went out and bought Cat skis and Snow Trackers for his 2016 LTX. They steer easy, and there is virtually no push or darting. They are ugly, and they are not cheap, but they really work!
savageman69
- Apr 21, 2014
all 3 of us with 14 cats also run semi snowtrackers...i love them..last set lasted me almost 8000kmsI agree 100%. I know I sound like a broken record, being such a fan of the Snow Trackers, but I have Cat skis with semi-aggressive Snow Trackers on my 2015 LTX, and my riding buddy was so impressed that he went out and bought Cat skis and Snow Trackers for his 2016 LTX. They steer easy, and there is virtually no push or darting. They are ugly, and they are not cheap, but they really work!
I don't have snow trackers on the Viper but I put them on the Doo and they definitely work as advertised.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
If you really want to make things easy on your wife, install snowtrackers and rouski wheels on those cat skis.
You will not regret it.
Red Hornet
- Mar 9, 2017
- Shiocton,Wisconsin
- 2014 Yamaha SR Viper
Just love the snow trackers.
