Nitroya
- Nov 12, 2012
I will be replacing my front A arm bushings looking for any tips or problem areas. Sled as 14 000km.
srxpert
Use a threaded rod to suck the new bushings into the A arm. Shane
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Loctite all bolts.
Bahr05
Get 12-pack of beer.
09nytro
Don't ride it with front end off !
raginyamaha
most important part of the job right there....Bahr05 said:Get 12-pack of beer.
Nitroya
- Nov 12, 2012
It drove well with the front end off surprisingly!!
Nitroya
- Nov 12, 2012
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Does anyone know if there is a step by step thread out there for this also? I just started mine and I'm sure there must be a few things I can avoid removing or cussing at. I have done a search but to really no avail. Thanks
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
My bushing kit will be here sat, so that's my weekend project. I was actually gonna just follow grizz's subframe removal guide and stop once the a arm bolts were accessible. Idk if that will help u or not
canoehead
- Jan 14, 2011
- NE, Alberta
bushings
Thanks I had a look at them on Ronnies Fiche. Now that I know the upper nuts are weld mounted my fears have been pretty well put to rest. I read the rear lowers are the beotch but if I pull the tie rod rubber boots back they're right there. I guess the worst is pulling the bumper and the nose cone which isn't bad if I have to.
Thanks for the reply again!!
13NytroXTX
Re: bushings
Yea the lower rears are a real pain but you can get them off without taking the boots off just need a long 12 point wrench to reach way in there.
canoehead said:Thanks I had a look at them on Ronnies Fiche. Now that I know the upper nuts are weld mounted my fears have been pretty well put to rest. I read the rear lowers are the beotch but if I pull the tie rod rubber boots back they're right there. I guess the worst is pulling the bumper and the nose cone which isn't bad if I have to.
canoehead
- Jan 14, 2011
- NE, Alberta
Re: bushings
How do you put them back on?13NytroXTX said:canoehead said:Thanks I had a look at them on Ronnies Fiche. Now that I know the upper nuts are weld mounted my fears have been pretty well put to rest. I read the rear lowers are the beotch but if I pull the tie rod rubber boots back they're right there. I guess the worst is pulling the bumper and the nose cone which isn't bad if I have to.
NB-NYTRO
You can drop the belly pan.. I had mine off from when I did the oil change and left it off to do the a-arm bushings..
I strongly recommend the Ulmer Racing bushings.. Amazing kit.
