Scooter02
- Nov 26, 2007
- Oak Creek, WI
- Yamaha Viper LTX LE
What is the best way to install the upper idler wheels in a 2007 Apex GT skid? I ended up buying a new shaft because I damaged the threads in the old one and don't feel like buying one again. Thanks for any suggestions.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Are talking about putting new wheels on the shaft or installing it the skid back in the sled?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
If putting new wheels on the shaft use a deep well socket to press the one wheel on (hitting the socket with a hammer). Then install the shaft into the arm, now flip the skid on its side with the wheel you installed facing the table. Use the same socket and hammer to press the other wheel on.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Thread the bolt back in, with a dead blow hammer hit on bolt until the shaft is thru the wheel, and do the same on the other side. the suspension has to be out of the tunnel.
Scooter02
- Nov 26, 2007
- Oak Creek, WI
Thanks for the replies. That's the way that I had planned on installing the wheels back onto the shaft, but I was second guessing myself as I didn't want to wreck another shaft!
