Firecat_Freak
Hello, I f'd up and didn't take note of the washers and spacer for the upper idler wheels on my apex gt 06. One big washer, smaller diameter washer, and the white bushing. What is the configuration? Please help, thanks
vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
Check the parts fiche, good detailed view.
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
You probably have it figured out by now, but by looking at my non GT Attak, from outside heading in, it is bolt, small washer, tunnel mounting bracket, white plastic collar, large washer, then the bearing.
Firecat_Freak
Actually, the parts fiche does not show the order of the idler wheelncompared to the two washers.....Check the parts fiche, good detailed view.
The idler is on one one fiche, the washers on another. Thanks for the help though.
Firecat_Freak
I ended up installing big washer and smaller washer on the inside of the wheel, then idler, then white plastic spacer with the bolt and washer outside. If anyone has the correct gt service manual it should show the whole thing.
