Reverse grabs snowflap
We all had this problem with the RX1's. I put on the 12 in. Yammi flap. Looks better IMO, and no more backing over it in reverse. Here's the red one on an 03 Shorty.
Had the same problem with my 04. Changed to the shorter flap and no more problems....
Take a ruler and marker put a level line on it ,take a utility knife or shears and trim it. Studs will ruin it in a hurry. :rocks:
dburu2 had the right idea.
I've been reaching back, and holding the flap up. Also, you can drill a hole in the bottom of the flap, and use a bungy to the handle to hold it up.
I took a bungee cord just long enough to hook one corner clear under the edge where it is attached and over to the otherside. I forced the flap out and away. Worked perfectly. Of course shortening it is probably a better solution in the long run.
Mine does it also .But my sled doesn't back up .it takes like full thottle to make it move.If you hit the throttle hard it makes a load noise and the drive belt in the big pulley opens up and pulls the belt in the pulley.Then I have to pull the cover offand pull the belt out.
Seems to goes into reverse but doesn't seem right
snowflap
Wahts the part NR for the short flap and HAPPY NEWYEAR to you all:
