SharkAttak
has anyone had problems with there reverse, when i put it in reverse and hit the throttle it goes backwards for a second and then makes a clunking noise and snaps back into forward, is there an adjustment?
Tork
SharkAttak
thanks Tork
Tork
No prob. post back up and let us know how it goes.
I would say 2 dozen or so people have had this.
It is supposed to be on the dealer checklist to adjust before it is delivered.
Len Todd
Those adjustments have to be right on the money and when you are done, make sure the nuts on the rods are tight.
SharkAttak
Tork said:No prob. post back up and let us know how it goes.
thanks tork it worked, took alittle bit to adjust, i don't understand what happened it was fine last year, i got done the other day changing the oil & filter and the chaincase oil then i started on the stand and put into forward and then reverse when it started to go in reverse it just popped back into forward, can't understand it
jkenosh
maybe the gears are wearing in, thats the only thing i can think of, did you use thinner oil?
SharkAttak
jkenosh said:maybe the gears are wearing in, thats the only thing i can think of, did you use thinner oil?
yes, i used valvoline 80w-90 durablend gear oil
Tork
sometimes it ends up tooth to tooth and wont engage, just got to blip the gas and try again in a new position so the gears can mesh. That could make it pop out or make the grinding noise. Prolly the adjustment was marginal from the begining, and you adjusted it to specs now
SharkAttak
Tork said:sometimes it ends up tooth to tooth and wont engage, just got to blip the gas and try again in a new position so the gears can mesh. That could make it pop out or make the grinding noise. Prolly the adjustment was marginal from the begining, and you adjusted it to specs now![]()
thanks Tork
xcsp
Revrse Popping out here to!
Does drive chain tension have ANYTHING to do with the reverse system on the sleds?
I had the dealer adjust the reverse linkage last year when the sled only had a few hundred miles on it-had worked fine since.
I had adjusted the drive chain tension a while after that. All was fine for 1600+ miles.
Yesterday, went to put it into reverse on different occasions and either it would pop out, or if I moved the sled some it would go in and back up, but a few times it made some grinding noises while backing.
I'll have to check the linkage adjustments, but are these reverse systems that touchy??
Update: checked the horizontal linkage measurement-right on at 27mm, so I adjusted the free play (which there was some) out of the vertical adjusting rod, then,backed it off 1/4 turn and it worked great-at least with the sled on the trailer, rear of sled raised to allow the track to rotate freely.
- 17K
