Rich on fuel....
erexett
Sweden
I have problems with to much fuel around 6000 rpm and 1/4 throttle. It splatters(?) and missfire. After a while it only goes on 3 cylinders. It takes a real WOT to "clean" it up so it will go on all cyl again. Is it possible to adjust the needles or should I do something else...?
Snow fever! What altitude are you running at? I´m at sea level up to 1500 ft.
TORS! I disconnected the TORS and now i seems OK. I´ve just made a short test run and the problem was gone. Shall do more testing tomorrow.....
chek if u have a bend on your retur hose from the fuel pressure valve!
had the same problem on my RX, and that was the problem.
