glred
Is there a fully clipped ripsaw available with the pre molded holes??
I would think fully clipped is the way to go, or am I wrong??
4Fighter
I'm just going to punch mine cause I don't plan on running extroverts.
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
The Ripsaws with the pre-molded holes only come in a every 3rd clip version. They do make a regular fully clipped Ripsaw. As far as fully clipped vs. every 3rd clipped goes the debate on that could go for many pages on here. I see so many opinions on this I don't even know what to make of it anymore. From my own experience riding on them the every 3rd seem to get better hyfax wear if you are riding in decent snow conditions. The key is decent snow conditions. Everyone has a story about hyfax sticking at one time or another but you always have to wonder would the same have happened if you were running the opposite set-up or does your buddy next to you who has the opposite set-up and doesn't have problems have his track as tight as yours or his suspension set-up the same? There are way to many variables. I have seen 02 Viper owners switch from the old fully clipped Yokos to Camo every 3rd clipped and double their hyfax life. If you are running studs or have a higher than average horsepower sled some have had issues with the track ratcheting under high loads on the every 3rd clipped. The only real way to fix that is a fully clipped track with extrovert drivers. I personally believe that for most consumers the every 3rd clipped tracks are fine.
glred
thanks for the info
what is the warrany on the pre-molded tracks.....what studs must you use??
Port-Parts
TY Advertiser
- Sep 18, 2003
- 2012 Nytro RTX
I believe the warranty on them is 1 year and you must run Woody's studs and backers for the warranty to be in effect.
