wolfe9904
- Dec 29, 2013
Hay guys,
Currently have 2008 Phazer. Have a riser block on it currently but can tighten the bolts down all the way cause they hit the bracket support. What are the pivot block options for this sled.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Lake effect risers are very nice.
Dalton
- Mar 13, 2013
- Chippewa Falls, WI
- Sidewinder XTX SE 141
Yamaha Phazer 2007 GT
Lake Effect is definitely the way to go. I got the 2.5" pivot one in silver and love it.
michdog2011
I have 2" ROX pivot Riser, Nice set up and no issues with cables - Gone Blue is running with 2.5 Lake Effect (Jeweler finish/A+ unit) .
Gone Blue
- Oct 11, 2006
- Howell, Michigan
wolfe9904
- Dec 29, 2013
I was hoping there was one that fit on the bottom, so I could run a whole different riser and could do away with the stock. I tried the powermadd one , but I could not tighten the bolts all the down cause the heads hit the supports . So I can run a riser straight up and down..Here are pictures of a 2.5" Lake Effects pivot riser on my 09' Phazer RTX. You do need to re-route some cables on and around the handle bars and riser. Easy to do. G.B.View attachment 100617
View attachment 100613 View attachment 100615
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Snowmixer
- Oct 29, 2010
- Snohomish, Washington
- 2007 Phazer Mountain Lite
2008 Phazer MTX
2012 Arctic Cat M800 153
Is this similar to what you're looking for?
https://www.denniskirk.com/595126.s...m_medium=cse&gclid=CJHIwIyK-cECFdSTfgodsh8Aug
I'm trying to picture what part of your current setup is keeping you from being able to tighten it up all the way. Any chance you can post a picture?
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
I went cheap and installed a PowerMadd 325 2" PowerRiser.
I did the same thing. The powermadd works great and lets you get the handlebars a bit more forward. I thought about putting it on the bottom, but changing the location of the stock riser throws your windshield off to. So if you have a windshield, you don't want to change the stock location.
If you are going without the windshield, then your options are wide open. I was not able to remove my windshield bracket, as the dealer that assembled it used some crazy threadlocker that busted two allen wrench tips off on. So the stock windshield and riser position will stay. I have used the same pivot adapter on the Apex, and it too worked well there.
flyinghigh
- Nov 20, 2014
- 2014 Phazer xtx
Just want to double check this with everyone....I put on the 2.5 inch lake effect riser today on my 2014 XTX. I had to remove the windshield and cut the top cable tie to get enough slack...at least I hope it is enough slack. Can someone confirm this for me? Any draw backs to the removing the windshield...did not seem to be any way to make the cables long enough with it in place. Seems so small, I doubt it does much to block the wind.
Thoughts?
Thoughts?
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
The cables and windshield should have nothing to do with each other. They will route down the riser with or without the windshield.
Did you put the 2.5" on top or bottom of the stocker? Pics would help. You may think it is small but the windshield does help.
flyinghigh
- Nov 20, 2014
- 2014 Phazer xtx
It is the pivot riser ...so it will only go on the top The windshield mount makes a huge difference on where the cables go. I would be happy to post pics...is there a thread with instructions on how to do that?
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
Do that, because even in the photos above of their riser install, you can see that once the throttle cable is run under the bar, nothing from the windshield is an issue. You can run the cables down the middle of the mount, or down the side. It makes no difference if you have the windshield on or not.
If someone cable tied your brake lines or throttle cable to the windshield mount, then they setup your sled wrong. The windshield and handlebars are one of the things the dealer does setup. I know this as my dealer back in 2006 installed my windshield bracket upside down. It made no difference other than it was 1/4" taller and I cannot use the cool Yamaha windshield bag, as there is a bar in the way.
Post up the pics and we will take a look.
MikeWalters
Where did you get the 325?I went cheap and installed a PowerMadd 325 2" PowerRiser.
