BombaPolaYama
This is not the case! I now have to replace mine due to major slop in the kit.Thankfully that will be it unless something breaks and needs replacement. You know the Engineering Department does not wrench on this stuff and if they do it is already disassembled by someone else thanks for the feedback.
BombaPolaYama
Do you have a link to this steering kit... I can't find it on Yamaha Canada's site? Also, were you able to buy it in NL or did you have to order it? Thankspart number sma-beari-ng-kt cost is $39.95 cdn available through Yamaha! check the Yamaha motor website under accessories for any phazer.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
it this what you looking for?Do you have a link to this steering kit... I can't find it on Yamaha Canada's site? Also, were you able to buy it in NL or did you have to order it? Thanks
https://www.yamaha-motor.ca/eshop/d...e=2016+Phazer+X-TX&unitGroup=SM&unitYear=2016
BombaPolaYama
Perfect, thanks.it this what you looking for?
yam429
- Jan 18, 2009
- Saint Michael, MN
- 2009 Nytro XTX, 2010 Vector LTX, 1981 SRX 440, 1989 Inviter, 1991 Snosport, 2004 Snowhawk
- Saint Michael
Is there any way I can get the Yamaha heavy-duty steering bearing kit in the U.S. because Yamaha Canada will not ship it to me?
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
I have this yamaha kit installed and its a piece of sh*t (video is after 500km of installing the bearings)
It does take up some of the slop, but it still rocks quite a bit even brand new. Seriously get the one from UPBushman or Schmidt. After this video I did install some machine bushings (big washers essentially) to address some of the vertical play and it helped a bit
If you have play here, you probably also have play in the ski bolt/bushing, and lower ball joints (I am replacing the bolts/bushings/lower ball joints this fall)
yam429
- Jan 18, 2009
- Saint Michael, MN
- Saint Michael
Ok thanks!
UP bushman
It's been a while just a shout out to all the great comments on the product from you guys thanks again Rob.
Old dude
- Jan 20, 2021
- Michigan
- 2008 Yamaha Phazer
The Plastic Bushings part# 8GC-23362-00 & Steel Collars part# 90387-10008-00 on the Pivot Assembly where Idler Arm bolts connecting to Tie Rods are less then desirable on these sleds. My 2007 Mountain Lite were super sloppy after 1300 miles. I made Bronze Bushings and Plastic Washers for the Pivot Assembly where it connects to Idler Arm in the Front Frame.
These pictures show the stock setup and the new Bronze Bushing & Plastic Washer setup. This has been updated since this thread started with some more detail. The Steering Pivot Arm Bushing Kit includes 2-Bronze bushings, 4-Delrin washers with 2-Delrin shim washers for under linkage arm and 1-Delrin shim washer on top of linkage arm for steering pivot arm are now available for $54.00 + shipping $12.00 US, $22.00 Canada, $25.00 International.There is complete instructions on how to install the Steering Pivot Arm Bushing kit on page 6 of this thread.
For purchase of Kits you can contact me via PM or email uptime@gmx.us thanks.
Old dude
- Jan 20, 2021
- Michigan
Got your kit last week. Question. Should I use red loctite on all the bolts when I put everything back together.The Plastic Bushings part# 8GC-23362-00 & Steel Collars part# 90387-10008-00 on the Pivot Assembly where Idler Arm bolts connecting to Tie Rods are less then desirable on these sleds. My 2007 Mountain Lite were super sloppy after 1300 miles. I made Bronze Bushings and Plastic Washers for the Pivot Assembly where it connects to Idler Arm in the Front Frame.
apeddigrew
- Mar 5, 2011
- St. John's, Newfoundland, Canada
i am aware of the age of this post but did you have any measure of success with the steering? my 07 VL is a nightmare to steer at the moment.... all comment welcome. thanksis this why mines so hard to steer and it just jerks around?
By nightmare do you mean stiff or sloppy?i am aware of the age of this post but did you have any measure of success with the steering? my 07 VL is a nightmare to steer at the moment.... all comment welcome. thanks
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
This will fix sloppy steering however @UP bushman is no longer making these. Look at Ulmer and Schmidt Brothers.
hyde_auto_body
- Apr 9, 2023
- Otter Lake, MI
- 2008 Nytro MTX, 2012 Nytro XTX, 2000 SRX 700, 1995 V-max 4 800
We use a machine shop to make many different things for my shop. If anyone has simple blueprints or dimensions for this kit or something similar I'm sure we could reproduce it. Let me know.
