RX1Jim
I am thinking of putting a roller on the secondary clutch of my 2003 RX-1. If you have put one on your RX1, please let me know of your opinion/experience with it. I am thinking of buying the roller from Pioneer Performance. Thanks!!
04rxw10
I have one and love it.
I bought it from another member on this site.
Mad Powersports
I have one on my 700 and it's a great upgrade.
Tf18
Roller Secondary
Son just bought a roller secondary for his 04 Warrior. Just wondering if there is any gains with the unit? or is it just smoother?
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
- www.yamaheater.com
- 2007 Attak - LOVE my sled!!!
Have one and love it!
Myself and many people have had the stock one (Pre '06) break one or more of the button towers.
Therefore I didn't want to lose ride time again and replaced it with a Roller Rooster secondary.
It's smooth and it works! Hasn't broken yet!
If the roller secondary you are looking at doesn't replace the button towers, look elsewhere, the towers are the weak link.
RX1Jim
Thanks guys for the info.. Where did you buy your roller secondary kits from? The only place I have found that offers them is Pioneer Performance. Thanks and Happy Thanksgiving!!
Mad Powersports
The one on my SX is a Hauck Magnum Powershift. You may want to check with them. Pat is a great guy to deal with.
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
The Team secondaries work pretty well also, here is a link to someone with one.
http://www.ty4stroke.com/viewtopic.php?t=49893
It also has a suggestion for the helix angles.
04RXW10 has one also, he can fill you in on his.
Hope this helps!
Hope this helps!
Len Todd
You might want to PM yamadog1. He has several clutch setups and has compared them. I saw a roller secondary set on his immaculate bench.
rx1ryda989
I run a TEAM Roller secondary myself, You dont gain that much in performance, you will notice more consistent shifting and lower belt temps. It is a nice upgrade, but not necessary IMO.
RX1Jim
Thanks guys, this is all good information. I appreciate all your responses. I am looking for more consistency in the shifting. The stock setup, at least mine, does not provide consistent backshifting.
Len Todd
A roller should increase/improve backshift over the stock setup. However, if you increase/improve backshift, there is a very high likelihood that you will also increase engine braking. That may not be a desirable side-effect.
Mad Powersports
Len Todd said:A roller should increase/improve backshift over the stock setup. However, if you increase/improve backshift, there is a very high likelihood that you will also increase engine braking. That may not be a desirable side-effect.
That is where I believe they shine. I run my SX in tight twisty trails. The engine braking (I barely notice it) helps slow down for the next corner and stabbing the throttle on exit there is no wait for the clutch to catch up. Your gone.
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
Mad Powersports said:Len Todd said:A roller should increase/improve backshift over the stock setup. However, if you increase/improve backshift, there is a very high likelihood that you will also increase engine braking. That may not be a desirable side-effect.
I agree, not only that, but a good roller secondary eliminates the weak button towers, making it less likely to ruin a trip for you!
Know this from prior experience.
rx1ryda989
Just dont forget the secondary tool if you have to change a belt!! Real pain in the #*$&@ without the tool for the TEAM Industries roller. Trust me, I learned the hard way at -10 degrees at 2am.
