- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Engagement is 3800 to 4000 rpm, slightly higher than stock, but it is made for trail riding, no harsh or jerky engagement. The mpg stays the same as it was stock as well. The engine braking is reduced, but it is not any harder engagement when you reapply the throttle for acceleration, the clutches backshift much better and the sled will be much smoother throughout.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
Sounds great
I'll be placing my order anytime soon
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Srxspec said:Engagement is 3800 to 4000 rpm, slightly higher than stock, but it is made for trail riding, no harsh or jerky engagement. The mpg stays the same as it was stock as well. The engine braking is reduced, but it is not any harder engagement when you reapply the throttle for acceleration, the clutches backshift much better and the sled will be much smoother throughout.
Hi Allan
Do you know how this works together with the Excell header for Vector? Will the Holtzmann carb springs add any value? Any noticeable difference?
Nick1945
Allan,
Thanks for the super fast shipping of my new clutch kit. Ordered it Tuesday, got it a couple of hours ago, only 2 days, now thats great service.
Thanks again,
Nick
Thanks again,
Nick
salestim
I have never had a sled clutched but considering on my 09 Vector GT. I understand the clutching will give more in the mid range but does it take anything away from the low end?
Nick1945
salestim said:I have never had a sled clutched but considering on my 09 Vector GT. I understand the clutching will give more in the mid range but does it take anything away from the low end?
Give Allan Ulmer a call, and he will give you all the info you need to make your decision, really great guy.
Nick
You will not be dissapointed the gain is huge.I have tried his kit on aspahlt I was running faster then most rx1's.On the lake in 1000ft drags I beat alot of big sleds with a combination of other things.Beat f7's,fushion 900's,apex's,rx1's,zr 800's.
swmichvector
- Jan 27, 2009
- Clare, Michigan
- 2011 NYTRO
hey ulmer, how about a better deal for me since i started the post and have made you some money?
birkebeiner
- Jul 27, 2009
- Norway
- Norway
swmichvector said:hey ulmer, how about a better deal for me since i started the post and have made you some money?
