Mad Dog
- Nov 20, 2006
I swear I read somwhere that you could get the guage to light up, or the headlight to turn on with out the engine running if you pressed certain buttons in the right order. I did a search and can't come up with anything! may be it was up, down, up. down, left, right, left, right, b, a, b, a, select, start, select, start
thanks for the help!
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
pull the kill switch up to the "on" position, then press and hold the thumb-warmer switch in the down position, then turn the key to the "on" position ... continue to hold the thumb-warmer switch for 8 seconds ... the headlights and the gauge will then light up without the engine starting.
this works on my nytro
