Bakemono
- Oct 5, 2004
- Edgerton, WI
- www.myspace.com
You would think that the Vector would have a deeper tone to it because the cylinders are bigger.
I personally like the sound of RX-1s with turbos the best.
They have the snarl that all RX-1s have, but they also have the whine of a turbo.
Tork, I like your car references however I would disagree about sound of a Yammie 2-stroke. I think they sound more like big V8s.
I would say that Poo/Doo/Cat sound more like Ferraris with the more high-pitched sounding big twins.
I think all sleds sound nice, even lil fan-cooled 340s. I used to love how my Phazer sounded when it hit 6,000 rpm and the reeds opened. *BRAAAAAP*
Hebi
Hebi
rupprider
Hebi, that was your chin strap hittin' your helmet! Or, did you have a bowl of chilli at the last stop?
YamahaRx-Warrior
Sounds like my rx-warrior muffled a little more. Has a nice sound and is very quiet. My mom loves it
Trxster
Are the pistons bigger or does it make up the difference with the longer stroke?
Tork
UM I think it is both. At 8600 aprox RPM you can get away with a longer stroke.
It is 3/4 of the FJR 1300 sport touring motorcycle engine.
twomorestrokes
exhaust sound
Yeah, has a bigger bore and longer stroke to end up with almost the same cubes.
My vote for the best time to listen to the exhaust is at a good clip across the flat field, turn your head and listen behind you. Sweet sound!
(watch out...going into a trance in this situation could prove harmful)
MadMax
Tork said:UM I think it is both. At 8600 aprox RPM you can get away with a longer stroke.
Tork---- You aint got the balls to ride at 8,600 rmps... Ooooooooooooops!! Looking at your avatar I guess you do!!!!!
MM.
