RS Venture 66
- Feb 16, 2005
I removed the skid from my RS Venture to replace hyfax. Prior to re-installing I decided to grease all shafts & Bushings. I noticed on two bushings on the lower end of the front shock that grease was squirting out around the threads. it appears that a bead of welding is used on the bushing as a location to insert the grease fitting. Poor welding around threads of the grease fitting is the cause of the grease leak.
Has anyone noticed this?
1430 km - hyfax replaced
780 km - clutch shimmed
Excellant gas mileage - 21 mpg avg (imperial)
Picture of 2006 Viking
p0wd3rp1l0t
not a problem with my rage...but where is that sled on the yamaha site? is that the late release sled?
§tylus
- Jan 16, 2005
Greese is leaking out around all the fittings on my wifes Vector. I'm going to pull the skid and thread them or weld them this summer. I put JB weld around them to get me by till I can fix them.
RS Venture 66
- Feb 16, 2005
rupprider
A couple zerks on the wifes 2000 500dlx leak bad enough to make greasing a real chore. RR
Loomy58
Ditto on my vector. but mine is the front w-arm both top and bottom.
Jeremy
Jeremy
I have the same problem on my Venture. 4 of the fittings in my rear skid are like this. The worst is the front shaft (top of shock). I told the dealer and what he said to do is loosen the track to take the pressure off. Not exactly the solution I was looking for. I will take the skid out this summer to fix this and change the hyfax.
